M400 waste spark v sequential
I have always run waste spark ignition with blown methanol. I want to change to Motec ignition, what is the advantage of sequential ignition (CDI 4) over waste spark (dual channel motec CDI)?
If I use CDI 4 I will need either single tower coils or COP. I need the biggest spark energy available running big boost and methanol, which is best?
Can you give some millijoule examples of the coil output you suggest, what can I expect?
Thanks for your help.
