4 single CDI units V 4 chanel CDI?
Mon Aug 18, 2008 10:41 pm
by SimonP
Hi all, I thought id throw this up as an idea.
Would it be possable/feasible to use 4 late model bike CDI units (one for each ign output on m800) to run coil on plugs off a cbr honda?
And would a system like this cope on a boosted aplication?
Thanks, Simon.
Re: 4 single CDI units V 4 chanel CDI?
Fri Aug 22, 2008 2:49 pm
by RossB
This may work but would really depend on the type of coil/CDI combination you are talking about. We would need some more detailed information of exactly what you are using to be able to advise you on this.
Fri Aug 22, 2008 11:35 pm
by SimonP
Thanks Ross,
I did a bit more homework on this today and found out that the coil on plugs (cbr600) that i have are not CDI compatable. Time for a rethink.
Sat Aug 23, 2008 5:21 am
by IDP
Yamaha R7 1999/2000 model
and Yamaha R6 2004/5 model coils are CDI compatable.
What CDI units are you thinking of running?
Wed Aug 27, 2008 9:39 pm
by Stuie38
I asked exactly the same question to some Motorcycle Ignition companies in Melbourne.
The response I got was that all the CDI units found standard on bikes have a built in Advance Curve.
I got told the only CDI units that would be suitable would be the HRC unit used on the RC45's , good luck finding one of those.
I did all the same investigating and ended up buying a Motec CDI....
Do you want a CDI unit/s (as the subject line states), or do you want coils to run off a CDi unit????
Wed Aug 27, 2008 10:21 pm
by SimonP
Built in ignition curve.. That would make the motec ign map look a bit wierd to compensate for that!
Ive just purchased some secondhand Diamond coil on plugs. I can run them directly from the M800 ignition outputs.
So ive given away the CDI option for now. Unless the diamond coils prove not up to the task.
