Motec ignition expander with 8 denso coils
Includes MoTeC CDIs, Ignition Expanders
Postby Daniel on Thu Jul 31, 2008 9:12 am
Hi
Just i am wiring up 8 ls1 denso coils to a motec ignition expander and wast sure if the ecu earth pin out of the coil was ment to go to A10 A11 (m800) or into the expander?
Thanks Daniel
Danic Performance
Daniel
Re: Motec ignition expander with 8 denso coils
Postby DarrenR on Thu Jul 31, 2008 9:46 am
Hi Daniel,
The ECU Earth pin on the coils should attach back to the expander GND, but this should be close to the ECU GND pins anyway, so wont really matter as long as the wiring is reasonably heavy from where you splice it in, to chassis GND.
Darren Reynolds
DarrenR
Return to Ignition systems
