Slm+ m150 flashing
Slm+ m150 flashing
Postby q8tech on Sun Oct 28, 2018 3:25 am
how do you guys get slm to flash like on the c1XX dashes on m150
q8tech
Re: Slm+ m150 flashing
Postby David Ferguson on Sun Oct 28, 2018 5:01 am
Use a dash or logger (L120/L180, etc) to configure the SLM. If you have a development license I suppose you could create a new SLM class with additional configuration options including flashing.
Postby z0mgchris on Tue Nov 06, 2018 12:52 pm
While I'm not 100% certain, wouldnt you use the dash manager > functions > Shift Light Module setup > "add > warning light, from here configure it for the lights you wish, then go to alarms setup > add etc and setup the 'option' for 'warning light'?
There is probably a method of doing this better /controlled by the ECU though.
z0mgchris
Return to SLM
