setting up SLM on M800
hi all,
i recently purchased a SLM (yay!!
)and hooked it up to my M800 (spending quite some time to fabricate the wires and using the black heat shrink thingy to make everything as professional as the SLM wires, yes i'm a perfectionist
). however when i tried to test it using the SLM table and rpm as the Y-axis, nothing happened.
then i realised that there is a "Adjust/General Setup/Communications/CAN Setup"
are we supposed to set it up here? cos mine is blank and previously i just used the CAN for USB connection to my laptop.
if so, can we just use any channel for SLM transmit? Data would be, 13 and Address would be...41?
help pls
help pls
