M400 + SLM without Aux Output Functions
PostPosted: Fri Feb 13, 2009 3:03 pm
by bing
Since i use SLM as warning function i don't need to wire up an aux output. Is it possible that motec can make a change in software, setting up SLM as warning + shift light without occupied the spare aux output?
Thanks,
Brian
Re: M400 + SLM without Aux Output Functions
PostPosted: Fri Feb 20, 2009 12:14 pm
by JamieA
This is more difficult than it sounds given the structure of the M800 software. It is often difficult to forsee when you build something the things that it may be used for, and as such it restricts things such as this. The request has been noted, but Im not sure that it will get done. The M1 ECU's will not have this restriction.
Jamie
