First Time Setup
Ok guys..sorry but I'm new to this game.
I decided to invest in the SLM instead of an AUX shift light for my Honda 600 which has CAN Bus between the ECU and SDL dash. I opened the SDL dash boot and made all the mods necessary which included CAN Hi/Lo, Battery Pos and Battery Neg...so I hook up the SLM and turn on the ignition....no lights flashing or nothing..mmmmm
Then I go into the ECU Manager and see options for CAN Bus SLM....so I choose CAN 1 Data and select 41???
After this I then go into the SDL config and try to setup so comms in the 'Input'...Communications...
The truth is I didn't have a clue how to set it up and wondered if I had wired it right??
Then I went into Functions (SDL) and 'Shift Light Module' and created a condition for the lights to come on if engine temp equaled less that 60 degrees. Saved the config and sent it to the dash...Bingo!!!! I was blinded.
The good news is that it's obviously wired right as I have some control but how on earth did I configure it? Was it the ECU part or does it work straight out of the box?
Now I'm wondering what the difference is between the ECU setup and SDL setup and which one does what?
How do I setup my shift light table for RPM?
