SLM via ADL
PostPosted: Fri Oct 08, 2010 8:42 pm
by szekeris
Dear Sire,
I hawe a ADL old version. I use a SLM for shift light. It is working well. How to setup the bright without
use a new software.
I want to use a switch for dimming the light.
Best Regards
Istvan
Re: SLM via ADL
PostPosted: Mon Oct 25, 2010 1:56 pm
by DarrenR
Hello Istvan,
So you have the SLM operating from a manually set up CAN transmit template in the ADL - Version 3.2 software?
It is difficult to dim the SLM using the ADL, but it is possible. It involves calculating the value for each light and adding a value based on the brightness switch using the channel maths.
It can be complex depending on your configuration. 3D tables can also be used if not used for other functions.
