setting up SLM on M800
Re: setting up SLM on M800
Postby IJ. on Fri Apr 02, 2010 7:50 am
trainwrex wrote:Just wondering if anyone has a sdl program that they can send me or attach to this forum that has all the shift light conditions such as indicator ect..
Im not sure how to set it up??
This is how I did mine before I added the PDM's.
DASH Jan 12.U16
(236.39 KiB) Downloaded 1911 times
IJ.
Postby trainwrex on Fri Apr 02, 2010 10:46 am
Thanks for the reply mate. Ive just worked out how to do it now by looking at your file :).
The only other issue is that i cant select any of the indicators etc from the on/off tab. Now does all of these functions need to be wired into the SDL somehow?? Or is there a button or switch on the motec which can activate it??
trainwrex
Postby IJ. on Fri Apr 02, 2010 12:03 pm
You need a physical connection from the car's wiring into the SDL. I think from memory I tapped into the left/right indicator wires before the instrument cluster.
I wired those to av5/6, if you look at the input pins section of the file I sent they should be there, you then tell the SDL that 0=off and >5v=on
IJ.
Postby trainwrex on Fri Apr 02, 2010 12:29 pm
Cool thats what i thought.. I will leave that to the experts i think.. :D
Just one more questions as you seem to be full bottle on this. Is how do i get the gear selector to work on the SDL??
Ive imputed the gear ratios in the M800 but it doesnt imput them to the SDL??
Could you show me how this could be done also??
i.e where and how i would change any parameters..
Thanks again..
trainwrex
Postby IJ. on Fri Apr 02, 2010 12:38 pm
Sorry that's one thing I haven't played with, I run an auto trans so haven't had a need for it, I imagine it's like everything else in the SDL you need to genberate a channel for it then configure the table and assign it to the display.
IJ.
Postby trainwrex on Fri Apr 02, 2010 12:46 pm
Cool no worries mate.. Yeh the guy that installed it generated a channel for it so its on the display but it wont change gears??
Im just trying to play around with it until it goes back, so the more i can do the better..
Also it seems when i change teh sdl config for the SLM it dosent recognise it, and only recognises the M800 rev setup for the slm??
trainwrex
Postby IJ. on Fri Apr 02, 2010 12:52 pm
Post up the config you're working on.
IJ.
Postby trainwrex on Fri Apr 02, 2010 1:03 pm
Here u go mate..
tino_wrx is the SDL config
Tino_New setup is the M800 config
TINO NEW SETUP_2010_pump fuel.e35
(72 KiB) Downloaded 1883 times
Tino wrx.U16
(234.42 KiB) Downloaded 2194 times
trainwrex
Postby IJ. on Fri Apr 02, 2010 1:10 pm
Before I grab em, you can't configure the SLM in both the M800 and SDL it's one or the other ;)
IJ.
Postby trainwrex on Fri Apr 02, 2010 1:53 pm
Yeh I know. The slm has got more options so that's preferred I'd suspect
trainwrex
Return to SLM
