SLM fitment
Discussion and support for MoTeC's Shift Light Module
SLM fitment
Postby Martin on Tue Jun 23, 2009 8:20 pm
Would it be a problem if an SLM is fitted in a single seater car and it will be open to rain?
Re: SLM fitment
Postby IJ. on Tue Jun 23, 2009 8:40 pm
Something I can actually help with ;)
The SLM's are potted in epoxy so I can't see water being an issue Martin!
IJ.
Re: SLM fitment
Postby Martin on Wed Jun 24, 2009 4:05 am
Thanks IJ,
Thing is...the back end is all potted...but what about the front?
Wont water seep in underneath the LED`s and corrode its legs?
Who have stripped their SLMs? :)
Re: SLM fitment
Postby IJ. on Wed Jun 24, 2009 8:26 am
I'd assume the epoxy is right to the backs of the LED's (doesn't really make much sense doing it otherwise if they're trying to stop failures due to vibration)
When I mounted mine I wanted to remove it from the case that's when I found it's a one piece SLM ;)
Ended up building it into the dash.
IJ.
Re: SLM fitment
Postby SprinterTRD on Wed Jun 24, 2009 9:13 am
If the potting mix has not leaked out past the leds, I cant see how water can get in!
SprinterTRD
Return to SLM
