M400 + SLM without Aux Output Functions
Discussion and support for MoTeC's Shift Light Module
Postby bing on Fri Feb 13, 2009 3:03 pm
Since i use SLM as warning function i don't need to wire up an aux output. Is it possible that motec can make a change in software, setting up SLM as warning + shift light without occupied the spare aux output?
Thanks,
Brian
bing
Re: M400 + SLM without Aux Output Functions
Postby JamieA on Fri Feb 20, 2009 12:14 pm
This is more difficult than it sounds given the structure of the M800 software. It is often difficult to forsee when you build something the things that it may be used for, and as such it restricts things such as this. The request has been noted, but Im not sure that it will get done. The M1 ECU's will not have this restriction.
Jamie
JamieA
Return to SLM
