PDM config conversion
Postby ElectronSpeed on Thu Oct 01, 2009 8:46 am
Per the user manual:
"When changing the PDM type all configured inputs and outputs settings
will be transferred to the relevant pin number in the new PDM type."
I am changing a car from a PDM15 to a PDM30. It sure would be nice to reuse all the work put into the PDM15 configuration. Is it possible to change the PDM type in the configuration? I can not see the option.
thanks,
Eric Schieb
Electron Speed
ElectronSpeed
Re: PDM config conversion
Postby NathanS on Thu Oct 01, 2009 11:25 pm
The PDM type setting can be found under Global Setup. If you open your config file in PDM Manager, go to the Global Setup screen and double click on PDM at the top the Global Setup window will appear on which you will have the option of specifying the PDM type and its serial number.
This was introduced in PDM Manager 1.41.0015 which is the latest release version.
NathanS
Postby ElectronSpeed on Fri Oct 02, 2009 1:18 am
Got it. Thanks!
Eric Schieb
Electron Speed
ElectronSpeed
