PDM 30 Inputs & GM steering column turn signal switch
Postby NLSX454 on Sun Jun 08, 2025 4:28 am
Hi all,
Looking for help on wiring up my 1970 GM Turn Signal Connector to switched inputs on the PDM30. Attached is the IDIDIT factory wiring guide. The Purple wire normally provides +12V to the steering column switch and power is then distributed to whichever function is activated (left turn, right turn, etc.).
My question is, can I reverse this? Here is my plan. Using the right turn signal as an example. Since there are two output wires for the right turn signal (Royal Blue - Right Front) and (Green - Right Rear) from the column switch, I would use only one of these as an INPUT wire to the PDM. For the PDM Sensor 0V ground I would use the Purple wire (formerly the 12V wire) which would complete the switched circuit in the PDM.
On the Output side, I have separate 8A channels to drive the right front and right rear lamps. Separate because the brake light switch when active will trigger the left & right tail lights.
Thank you in advance!
Neil
GM Turn Signal Wiring.pdf
(174.45 KiB) Downloaded 59 times
NLSX454
Re: PDM 30 Inputs & GM steering column turn signal switch
Postby David Ferguson on Sun Jun 08, 2025 10:23 am
I think you have described it correctly, I would test using a ohmmeter to make sure the switches connect as you describe.
Postby NLSX454 on Mon Jun 09, 2025 12:31 pm
Thanks David.
I wired the rear turn signal inputs as mentioned and also wired in a brake pedal switch to a dedicated input and sens 0V input and had a good result. Both turn indicators work as well as the brake lights.
Thank you.
Neil
NLSX454
