Injector, ECU & COP Amps
Postby whrdnsx on Fri Jun 06, 2025 10:15 am
I'm making a Harness for the PDM & M150.
Got a K24 with K series COP's Bosch Motorsport 1600cc Injectors.
ECU will be powering 1 x 74mm Bosch DBW Throttle, Vtec Solinoid, Cam Control & Boost Control
I'm thinking of 3 x individual 8 Amp Outputs from the PDM for The Coils, ECU & Injectors.
Any Advice on if this will be adequate?
whrdnsx
Re: Injector, ECU & COP Amps
Postby Stephen Dean on Fri Jun 06, 2025 10:42 am
Injectors and coils can easily be on a single 8A output, with the ECU on another 8A output.
I prefer to keep the injectors and coils on a separate output to the ECU, so that the ECU can be powered without the coils and injectors also being powered.
Postby whrdnsx on Tue Jun 10, 2025 3:17 pm
Thanks for the advice, Ill change my setup.
whrdnsx
