KEYPAD
PostPosted: Fri Apr 11, 2025 6:46 pm
by godrift
i need to learn how to program on the keypad how to add page down and page up for the dash c127
my setup is motec m150, pdm30 and c127
i know that this will be by can message but no clue how to do it if you can help me.
thanks
Re: KEYPAD
PostPosted: Mon Apr 14, 2025 1:10 pm
You can load the Grayhill Keypad Button Rx template into the CAN Bus receive section to get the buttons into the the C127, once this is done, you can then select the received channels from the buttons into the Page selection tab in the Display Setup window for the Page Up and Page Down functions.
Re: KEYPAD
PostPosted: Mon Apr 14, 2025 9:21 pm
by godrift
Stephen Dean wrote:Hi,
i got lost here how to do it,, cos never done it.. is it possible to do it for me in my file ? so i can learn how to do it next time.?
thanks
Re: KEYPAD
PostPosted: Tue Apr 15, 2025 11:59 am
It is done in the Dash, not the PDM.
Re: KEYPAD
PostPosted: Wed Apr 16, 2025 10:34 am
by godrift
Stephen Dean wrote:It is done in the Dash, not the PDM.
but in the keypad buttons what should be added inorder to press and let the order works. as you know in the keypad button there is options under led1 and led2 to select options. this what im confused dont know what to use inside.
Re: KEYPAD
PostPosted: Wed Apr 16, 2025 11:02 am
Here are a couple of options on how to do it. Your dealer should also be assisting you with this as this is part of the contract that they have with us when they become a dealer.
Re: KEYPAD
PostPosted: Wed Apr 16, 2025 12:05 pm
by godrift
Stephen Dean wrote:Here are a couple of options on how to do it. Your dealer should also be assisting you with this as this is part of the contract that they have with us when they become a dealer.
first really thanks for the support, but i belive i made mistake when i said page up and down.
i meant the boost up and boost down to control from keypad not the display page.
sorry again. my mistake.
Re: KEYPAD
PostPosted: Thu Apr 17, 2025 3:56 pm
Same process, just us the Boost buttons instead.
Re: KEYPAD
PostPosted: Sun Apr 20, 2025 7:37 am
by godrift
Stephen Dean wrote:Same process, just us the Boost buttons instead.
thank you
