PDM15 shut down
I am having an issue where the power output is cut to either ecu,fuel pump or both randomly followed by a total shut down to the other electronics such as dash, blower , racelogic while on track.
I have the PDM supplying coils, injectors cam sensors , fuel pumps etc on separate outputs . The car has a cartek battery isolator. The sequence this shut down is as follows . Engine shuts down as it lost fueling or ignition and shortly after the Dash , racelogic timer and all other electronics independent of ECU turn off and i need to reset the CArtek switchto restore power . There is a delay of a few seconds between the loss of engine rpm and cartek total disconnection. I have confirmed this by looking at in car video and logged data .On the in car video i have overlayed throttle which is present indicating the DME still communicates .This is why i beleive is either fuel or ignition . The led flashing sequence of the CArtek suggests to check starter,alternator power cabling . What puzzles me is the initial ecu or fuel pumps cut followed by total disconnect
Does the PDM go into a total power down command if it detects an overcurrent ? What will be the overcurrent drawn for it to go into this mode if so ? I do not know when , at what overcurrent does the CArtek disconnects as well .
Thank you ,
Adrian
Thank you ,
Adrian
