CAN message output_Global_error
HI guys,
I see the PDM15 puts out on CAN messages for current output, overload, status ,global error that can be logged .
I use a Race Technology DASH2PRO as my logger . Would i be able to use the DASH2PRO unit and see the those output values in the the logger ?
I had a few instances where the entire power was cut on track and i suspect an overcurrent , overtemperature issue with the PDM . The car has CARTEK battery isolation system . I have checked all the connections ,replaced DT connectors and pins and entire CARTEK isolation system with both switches .
i have attached the config file .
Much appreciated,
Adrian
Much appreciated,
Adrian
