Toggle function problem
Hello
I try to set up a very simple output, on/off.
When I press the keypad button, the designated LED lights up and the output is being turned on, according to the "Monitor PDM" screen. As soon as I release the keypad button, the output turns off. At the moment, nothing is connected to the output pin.
Unfortunately I am unable to make the function to stay active. I have tried for hours, until my brain showed severe signs of numbness.
I do use the toggle function, yes.
This PDM also has a cooling fan being operated from another button on the keypad, there the output is toggled.
The file is not attached to this message, it can be attached later when I have access to the car again.
Any help will be greatly appreciated.
TIA
D
TIA
D
