Output not switching off
Hi All,
New to this forum and MoTec generally, just in the process of commissioning my PDM's and have run into an odd behaviour I hope some one can help with?
This issue is with my Indicators:
2 x 8A outputs used - RH & LH each running 3 bulbs
3 x Inputs used - 1 LH Switch, 1 RH switch, 1 Hazard warning switch
Config is simple:
Flash (RH Switch = true, true time=0.44s False time=0.34s)
OR
Flash (Hazard Switch = true, true time=0.44s False time=0.34s)
Left hand duplicates this but references LH switch in the first statement.
The Issue:
When I activate the indicator switches each sides behaves as you would expect.
When I activate the Hazard warning switch the RH indicators flash but the LH comes on permanently (actually it dims slightly in time with the flash condition)
When I deactivate the Hazard warning the RH side switches off but the LH stays lit.
If I check PDM Monitor, it shows the channels to be inactive.
Full disclosure the first time I uploaded the config I had missed the Flash command on the LH Hazard condition. this makes me think some how the code has got corrupted and somehow embedded?
Thanks in advance.
Scott
Config is simple:
OR
The Issue:
Thanks in advance.
Scott
