Hella Gen3 Ballasts and D2S HID Bulbs
Postby pooh_bear on Sun Mar 26, 2023 1:13 am
Thinking of start up current here....
Would it be OK to use 1 20A output for both HID headlights?
pooh_bear
Re: Hella Gen3 Ballasts and D2S HID Bulbs
Postby David Ferguson on Sun Mar 26, 2023 5:29 am
Have you tried hooking it up, and logging the current data using the PDM to measure it? if you don't have a digital storage scope with a current probe, then the PDM isn't a bad substitute, just setup a little bench harness with PDM can to your logigng device and test one light, then double the current draw if using one circuit.
