Hi, I'm currently working on a car with a double PDM setup and two keypads. I need to add a third keypad which replaces some of the direct inputs on PDM2. Unfortunately I have insufficient space within the CAN communications to forward all buttons from PDM1 to PDM2. From this topic I understand that it is possible to read the key presses from two PDM's (viewtopic.php?f=17&t=3445). Obviously the leds and brightness can only be controlled from one PDM (in this case PDM1).
How should I configure the keypad on PDM2 to read the key presses from the keypads configured on PDM1 without sending any data to the keypad (and causing erratic behavior)?
