Hi All
I'm having a mental block with this one
(Output) Fuel Pump
I need it to Run for 10 seconds when (switch Input) Ignition is True ...then not reset and run again until (switch Input) Ignition toggled off then on
Reason
Car has mechanical pump ..also has electric pump to get Fuel pressure up to start then not required to run and we don't want it to start again until we toggle the Ignition switch
I'm having a mental block on making this work ... I bet there is more than one way to do this
John P
