2 PDM'S with 1 UTC connector
Postby tsadilas on Sat Mar 12, 2022 11:26 pm
is it possible to use one utc connector for 2 pdm's installation? if its can you please provide wiring details? which of the 2 pdm's should i connect the 0v wire to ? do i have to disconnect the power from one of the pdms in order to connect to the other one via usb/utc?
thanks in advance
tsadilas
Re: 2 PDM'S with 1 UTC connector
Postby Stephen Dean on Tue Mar 15, 2022 10:25 am
It is possible to connect to multiple PDM's over the same connection to the CAN Bus. You can only connect to one at a time though.
To do this, you have the UTC connector wired to the CAN Bus (Note, the 0V wire is not needed and does not need to be wired in) and as long as the PDM's are no the same Bus, then you can connect to them by selecting the correct serial number from the list. They can both be powered at this time as well.
Postby tsadilas on Tue Mar 15, 2022 10:49 am
Thank you! This makes everything much easier
tsadilas
