12V in to wake up pdm30
Wed Jul 07, 2021 11:09 am
by TrophyBurro
Hi guys. Im at the planning stage on a pdm30 / pdm15 set up.
The only part I cant work out is how to wake the PDMs up. There does not appear to be a 12V in switch
when I look at the pin out.
Re: 12V in to wake up pdm30
Wed Jul 07, 2021 2:35 pm
When power is applied to the 12V+ stud, and the two ground pins are wired to ground, then the PDM will turn on when power is supplied to the stud, it does not need another switch to turn it on.
Thu Jul 08, 2021 12:00 am
by TrophyBurro
that being the case how do we turn it off from an external 12v switch?
I have a kill switch on the dash
Thu Jul 08, 2021 7:37 am
by greenamex2
Either cut the power to the pdm using a battery cutoff "relay/switch" or cut the earth's with the same.
What are you trying to achieve?
Thu Jul 08, 2021 8:23 am
by TrophyBurro
Just a switch outside of the can network that will turn everything off in emergency
fuel pumps mainly.
Thu Jul 08, 2021 8:51 am
by greenamex2
TrophyBurro wrote:Just a switch outside of the can network that will turn everything off in emergency
fuel pumps mainly.
So you want a simple "master switch" input and set any outputs you want it to shut down.
Thu Jul 08, 2021 10:44 am
by TrophyBurro
greenamex2 wrote:TrophyBurro wrote:Just a switch outside of the can network that will turn everything off in emergency
fuel pumps mainly.
perfect thanks sir !!
