PDM High Power Output Question
Postby vansingelm on Sat Jun 26, 2021 9:39 pm
Hi all,
Sorry for probably a verry dumb question but i'm gonna ask it anyway..
I want to power 6 coils in total (1,2,3 for bank 1 - 4,5,6 for bank 2)
when using a 20A high power output you need combine 2 pins,
can i use one pin for powering the coils for bank 2 and the other one for bank 2?
vansingelm
Re: PDM High Power Output Question
Postby greenamex2 on Sun Jun 27, 2021 4:49 am
Yes, that would be fine if each coil draws around 7.5A or less.
If they are more than this, I would combine the two pins and then feed all the coils from this (this is what I am doing on my VQ30).
How long is the run of wire from the PDM to the injectors.
greenamex2
Postby vansingelm on Sun Jun 27, 2021 5:41 am
Thanks for the information!
I will use Audi TT coils, any idea where i can find the specs for current draw?
The wire would be around 1.2m from PDM to the coils.
I was planning to use 18AWG wire for each pin
vansingelm
Postby greenamex2 on Sun Jun 27, 2021 6:18 am
If you can find the part number on the coil, I am sure the guys at Motec will have all the details (including dwell times etc).
greenamex2
