Brake force display set up
PostPosted: Sun Feb 21, 2021 3:40 pm
by nybimmers1
Hello folks ,
I am trying to set up a logic for brake force display on my track car .Basically when brake pressure goes over a certain brake pressure value to flash the brake lights but when below the specified ( brake pressure ) to just be constant on .
I have both brake light switch and brake pressure signals coming into the PDM over CAN . The brake lights are wired to only 1 output . Would it be possible to achieve such logic ? Basically when BLS condition is true lights stay constant on and when brake pressure signal becomes true turn/flash to off .I have attached my config file.
Much appreciated,
Adrian
Re: Brake force display set up
PostPosted: Mon Feb 22, 2021 9:36 am
Give this a try.
PostPosted: Thu Feb 25, 2021 8:13 am
by nybimmers1
Thank you Stephen ! Worked fine .
PostPosted: Thu Feb 25, 2021 8:46 am
Glad to hear. :D
