setting up fuel pumps???
Hello.
I am in the process of refining the pdm file on a rally car that I helped build. I am not sure how to set up the two fuel pumps, as I have a main pump and a spare pump. Both are plumbed in and wired in as well. Right now I have the main pump set up and running.
My question is how would I write the logic to turn off one pump if it draws too much, and turn the other pump on in that case so the car does not stop on stage??
Thank you as always..
Scott.
Scott.
