Low Amp draw warning light.
Postby remski on Tue Dec 03, 2019 1:38 pm
Hi.
I have a pdm15 and a 15 key motec keypad.
I would like the keypad warning light to come on if amperage draw is too low.
Case example:
My fuel pump draws 10A.
It draws only 4A if there is no fuel or the fuel is low and it starts to suck in air.
Just trying to add an additional element of protection.
Thank you.
Remi
remski
Re: Low Amp draw warning light.
Postby z0mgchris on Tue Dec 03, 2019 3:37 pm
Havent tested this myself - but you could potentially use Functions > setup say Fuel.Pump.Warning, have the condition set to be less than or equal to X amp of the fuel pump outputs current. Then apply that function to a light on the Keypad
z0mgchris
Postby remski on Mon Dec 09, 2019 3:13 am
Hi.
Just wanted to say.. that I did as you suggested and worked like a charm.
Thanks for your help.
Remi
remski
Postby z0mgchris on Mon Dec 09, 2019 2:05 pm
No problem at all Remi! Glad it worked :)
z0mgchris
