Combined ignition on, off and start button
Hi, I have a modern Ford Fiesta which comes with a single momentary button which provides ignition on, off and start functionality with the OEM electrical system. Is there any way of achieving this with a PDM? On the standard car the starter will only operate if the clutch is depressed.
Obviously the logic would need to ensure that the starter does not operate when the engine is running above cranking speed, I can receive rpm via can from the non motec Ecu.
I could go old school and simply fit a toggle switch for the ignition circuit, but where’s the challenge in that!
Has anyone got a configuration or tips they could share with me?
Thanks in advance
Toby
Thanks in advance
Toby
