Need some help setting up a keypad.
Postby sleeper on Sat Aug 31, 2019 9:35 pm
Hi.
Trying to get the keypad to do the following:
Example: button number 1 should do the following: ( lets say this is linked to Output 1 as a fuel pump)
Output 1 off: no light
Output 1 on: first light on
Output 1 fault: second light on
This is quite easy. But here comes the hard part ( for me at least)
Button number 1 should be able to turn on and off output 1 ( toggle) ( no matter what )
Output 1 will also be controlled by a canbus signal from the ecu, so that it starts if the PDM sees a rpm signal from the ecu.
So just to be clear:
button should be able to start the pump to prime\test the pump, lighting up first light
If PDM sees a rpm signal, it Should light up first light
If driver wants, he should be able to turn the output of even if the engine is running. ( override )
If output 1 trips for some reason light number 2 should light up.
Do anyone have a guide or some info on how to set this up?
sleeper
Re: Need some help setting up a keypad.
Postby adrian on Mon Sep 02, 2019 11:11 am
I have attached an example that should do what you want. The switch will change the state of the output no matter what. So if it is off the switch will turn it on, if it is on it will turn it off.
The RPM will only turn it on if the RPM is above the set value and turn it off if below the set value. If the output is already on (via the switch) the RPM signal will only turn the pump off by turning on and then off.
The first keypad light is set by the output being active and the 3rd light if there is a fault on the output.
Output Toggle.pdm
(32.52 KiB) Downloaded 1205 times
Postby sleeper on Tue Sep 03, 2019 1:58 am
Thanks you the help, But i can`t seem to open the file,
Error is error parsing file. ( tested on 2 different computers. ) 1.9.1.0012 software
sleeper
Postby adrian on Tue Sep 03, 2019 9:42 am
Sorry, I built that in the current beta version. You can download it from our website here
