PDM Input
PDM Input
Postby Donovan CR6 on Wed Mar 27, 2019 8:27 pm
Is there a floating voltage on the pdm inputs? I measured 12v on one today, is there enough current to cause a fire if this shorts out to ground?
Donovan CR6
Re: PDM Input
Postby Turby on Thu Mar 28, 2019 3:58 am
I believe PDM inputs usually work by switching the input pin to ground - so I doubt this would cause a fire! The currents are probably in the region of a few milliamps
Turby
Re: PDM Input
Postby adrian on Thu Mar 28, 2019 12:06 pm
The inputs have a 10k pull-up resistor to batt +. If you were running the PDM at its maximum rated voltage of 30V you would get 3mA.
Certainly not enough to cause any issues.
Re: PDM Input
Postby Donovan CR6 on Thu Mar 28, 2019 7:30 pm
Donovan CR6
