Polarity Reverse circuits
PostPosted: Wed Oct 11, 2017 9:10 am
by f1racr
Hi all,
Not new to PDM's but new to Motec PDM's..... we have just purchased a PDM30 for a project car we're building and I have a couple of devices (actuators and electronic handbrake) that have 2 wires for 12V+ and 12V- and so pretty straight forward to turn on, but when you want to return it to the other position we need to reverse the polarity.
Now I know how you would traditionally achieve that with a relay, but just wondered what other people have done on this scenario with a PDM and if there's anything any different or if we just take the relay approach ?
It just feels clunky to go with a relay when you have something so smart as the PDM....... so wanted to make sure there wasn't a smarter alternative.
Re: Polarity Reverse circuits
PostPosted: Sat Nov 04, 2017 8:55 pm
by f1racr
So I assume by the lack of replies that Motec themselves don't actually use this to answer customer queries as an official support mechanism........
What do others do if they want a definitive answer on something ? Is there any e-mail address etc ?
PostPosted: Sun Nov 05, 2017 7:39 am
by David Ferguson
Where are you located? It would be helpful if you would update your user profile with that info.
Normally MoTeC dealers or distributors in a particular country are responsible for the product support. For example, in the USA, here is a link to the page with email contact info:
http://www.motec.com/corporate/contactUS/
You can find this list for your country/region by visiting motec.com and clicking the support link on the upper right side of the page.
BTW -- to answer your question, the PDM can't do what you want directly, but I think you could use a Dual Half Bridge with two PDM outputs (or two ECU or Dash Aux Outputs) to do that. You may be able to drive such a device directly from the Half-Bridge Outputs found in the M1 Series ECUs also.
http://www.motec.com/s-ac-actuators/ac-dhb-ov/
PostPosted: Mon Nov 13, 2017 9:13 am
by Sharif@Forged
Is the actuator you speak of, a low current device like a boost control solenoid?
Low current devices can be controlled or switched by GPR M1xx directly through it's DHB. If it's a high current device like an DC inductive motor such as a fuel pump, cooling fan, etc...then an external driver would need to be used such as the RaceGrade SSD or the MoTec DHB.
