PDM 30 configuration
Have been chasing a solution for a PDM programming issue with conflicting results.
The auto elec has wired a three position switch for the headlights via a series of resistors to a single input on the PDM.
The set up is:
[list=]Off = 12V
Parkers = 6V - 9V
Headlights = 5V - 2V
Highbeam = 0V[/list]
The sparkie advises he has wired several PDM's this way and that its possible to configure the PDM to read the voltages across the identified ranges to control the three individually wired outputs for the headlights.
The good gents in Support have had a look and a think but are not aware of a solution at this time.
Appreciate and advice or sample programming where this may have been done before.
With thanks
Chris
The set up is:
[list=]Off = 12V
Parkers = 6V - 9V
With thanks
Chris
