Using new CAN Keypad to Control Boost and ECU Functions
I have an M800/SDL/E816/PDM setup which is yet to be wired up but thats coming soon ...
I wanted to find a neat way to select boost settings on the M800 and I noticed the CAN keypads do come with boost up and down stickers, but I'm not sure how this is achieved.
From what I read the CAN Keypad can hook up to the PDM and SDL as a switch would, but how does one get it to control ECU functions, is this done indirectly via the SDL?
Ideally I want to have one switch which toggles through boost setting and a second switch which when pressed defaults everything back to no boost control and whatever the wastegate spring is
Is this achievable and can the CAN Keypad be used for this?
Dan
Dan
