Setup Config Loom PDM 15
Postby TKManx on Wed May 14, 2014 2:57 pm
I have a PDM 15 and I want to program it before I put it in the car and do some testing.
After reading a few threads I believe this isn't an issue and can be achieved by simply wiring the Can Lo and Can Hi to the UTC and plugging in the Motec Can -> USB
So am I correct in that all I need to do is :
Connector A
A_26 - Battery Negative
Connector B
B_18 - Battery Negative
B_25 - CAN Lo - UTC Pin 4
B_26 - CAN Hi - UTC Pin 5
Connector C
C_1 - Battery +
Do I need anything else to the UTC or PDM to get it to communicate with the PDM Software ?
TKManx
Re: Setup Config Loom PDM 15
Postby mstech on Fri May 16, 2014 3:12 pm
That is correct.
mstech
Postby TKManx on Sat May 17, 2014 10:13 am
Thankyou
TKManx
