PDM30 Firmware update trouble
PostPosted: Fri Oct 19, 2012 2:34 am
by plosey
Hi, I have two of your PDM30's and i have moved to a new laptop. I need to update the firmware on one of the pdms from 1.4 to the new 1.5 (I can do this fine via the pdm software) however when i go to connect i get
Communications Error:
Read Operation Failed: PDM Halted reason code WRONG_CFG_VER
Attached is a screenshot of the error.
Re: PDM30 Firmware update trouble
PostPosted: Sat Oct 20, 2012 2:17 am
by GWRMOTORSPORT
Hi Plosey
I had a similiar issue when I tried to upgrade from 1.4 to 1.5 about a year ago,
If I recall the fix was to update the old 1.4 config file on the laptop into 1.5
and then update the pdm to 1.5 then resend the config file
Hope this helps
Steve
GWR Motorsport
UK
PostPosted: Sat Oct 20, 2012 2:45 am
by plosey
Thanks, Yes that is the email i got from Motec as well and it did work. was a simple fix just needed a point in the right direction, TY
