CAN output, confirm blank field = no message
Hi
we have checkboxes to 'select' weather status data is transmitted, that is great
for the actual optional CAN outputs, we dont have checkboxes but it actually seems to send, if something is defined, and not send, if something isn't.
if one defines the four additional, optional messages with an address, it appears that only data is transmitted for each byte that actually has a channel defined for it. In other words, if you have nothing in the box, there is no message transmitted at all. So if you have say a base address of 123 defined and you have a channel in the 1st and 3rd byte, that nothing will get transmitted on the second byte. Can someone confirm that this is indeed correct ? I am using this to have two devices communicate to a single device (one of the senders is the PDM and I didn't want it to conflict with the other sender).
Can we also confirm that if we have one of the messages defined with a base address, but dont populate any of the 8 fields, that no such message will be sent ?
THanks
THanks
