PDM Programming / Bus Load
PostPosted: Fri Jan 13, 2012 2:06 am
by Jakob
will there be a problem with programming a PDM when it is connected to a bus with already ~ 40% bus load?
Thanks.
Jakob
Re: PDM Programming / Bus Load
PostPosted: Fri Jan 13, 2012 11:52 am
by JamieA
no, that should be fine.
It is possible to do as you suggest, that is overload a CAN bus that is amost full, by connecting a UTC to it and programming the unit, but at 40%, you should not have a problem.
regards,
Jamie
PostPosted: Sun Jan 15, 2012 8:20 am
by Jakob
Thanks!
