UTC and PDM Manager 1.5
Tue Aug 30, 2011 3:12 am
by rdmahurin
Is anyone else have trouble using PDM Manager 1.5?
I have upgraded the UTC firmware to v1.13, and it still has comms issues; PDM Manager 1.4 still works fine, so I'm OK there.
Is there a later version of the firmware available perhaps?
Re: UTC and PDM Manager 1.5
Tue Aug 30, 2011 4:16 pm
by JamieA
Can you please explain in more detail what troubles you are seeing?
not connecting?
dropping out?
thanks.
-Jamie
Thu Sep 08, 2011 11:09 pm
by rdmahurin
Using PDM Manager 1.5 and the MoTeC UTC updated via the Firmware (v1.13) utility I downloaded from the web site, I can get the configuration from the PDM and save it without a problem.
When I try to send it back, I get a "Firmware version incompatible. Please update the firmware" error message.
Fri Sep 09, 2011 4:11 am
by PaulGM
The UTC is not giving you this error message, the PDM is. Before sending a configuration to the PDM with PDM Manager 1.5, the PDM's firmware needs to be version 1.5. When connected to the PDM, open PDM Manager 1.5 and go to "Online --> Update Firmware". This will update the PDM and you should be able to send the configuration.
Fri Sep 09, 2011 8:24 am
by rdmahurin
That did it - Thanks.
