PDM and Negative side Batt isolator
Thu Jan 13, 2011 10:57 pm
by yai111
I plan to use PDM15 with "Cartex" batt isolator. Cartex isolate batt on the Negative side. PDM user manual say that PDM should connect to batt isolator on Positive side.
Is it possible to connect batt isolator on PDM negative side?
Re: PDM and Negative side Batt isolator
Fri Jan 14, 2011 1:23 am
by chelspeed
Yes it must be because mines like that. PDM15 and cartek. Works fine.
Wed Jan 19, 2011 9:27 pm
by yai111
Thank you.
Mon Jan 31, 2011 8:56 am
by DarrenR
Yes if you look at the battery as an electrical component, breaking either side of the battery has the same effect of breaking the circuit, it makes no difference to the PDM.
