Configure PDM on Startup
Postby thorstengsxr on Mon May 03, 2010 10:32 pm
Hi
I’have a question about using PDM 15, M800 and UTC. My M800 is connectet to output xx of the PDM the UTC is connectet to canbus, Aux 8V and Aux 0V of the M800. At the first Startup only the PDM is connectet to Bat. and Ground so the M800 is off. Is it poosibel to configure the PDM without 8V for the M800?
Regards Thorsten
thorstengsxr
Re: Configure PDM on Startup
Postby Martin on Tue May 04, 2010 4:44 pm
Thorsten,
Only the very old can Cables used the 8v. On a UTC the 8v is not needed as the USB port supplies its power
Postby thorstengsxr on Tue May 04, 2010 6:11 pm
thorstengsxr
Postby DarrenR on Thu May 20, 2010 3:10 pm
Yes, the PDM is not compatible with the parallel port CAN Cable for this reason. It is UTC only.
Darren Reynolds
DarrenR
