PDM and Negative side Batt isolator
Postby yai111 on Thu Jan 13, 2011 10:57 pm
I plan to use PDM15 with "Cartex" batt isolator. Cartex isolate batt on the Negative side. PDM user manual say that PDM should connect to batt isolator on Positive side.
Is it possible to connect batt isolator on PDM negative side?
yai111
Re: PDM and Negative side Batt isolator
Postby chelspeed on Fri Jan 14, 2011 1:23 am
Yes it must be because mines like that. PDM15 and cartek. Works fine.
chelspeed
Postby yai111 on Wed Jan 19, 2011 9:27 pm
Thank you.
yai111
Postby DarrenR on Mon Jan 31, 2011 8:56 am
Yes if you look at the battery as an electrical component, breaking either side of the battery has the same effect of breaking the circuit, it makes no difference to the PDM.
Darren Reynolds
DarrenR
