KEYPAD
KEYPAD
Postby godrift on Fri Apr 11, 2025 6:46 pm
i need to learn how to program on the keypad how to add page down and page up for the dash c127
my setup is motec m150, pdm30 and c127
i know that this will be by can message but no clue how to do it if you can help me.
thanks
godrift
Re: KEYPAD
Postby Stephen Dean on Mon Apr 14, 2025 1:10 pm
You can load the Grayhill Keypad Button Rx template into the CAN Bus receive section to get the buttons into the the C127, once this is done, you can then select the received channels from the buttons into the Page selection tab in the Display Setup window for the Page Up and Page Down functions.
Re: KEYPAD
Postby godrift on Mon Apr 14, 2025 9:21 pm
Stephen Dean wrote:Hi,
i got lost here how to do it,, cos never done it.. is it possible to do it for me in my file ? so i can learn how to do it next time.?
thanks
E46 2JZ PDM30-1 Configuration.pdm
pdm 30
(99.04 KiB) Downloaded 31 times
godrift
Re: KEYPAD
Postby Stephen Dean on Tue Apr 15, 2025 11:59 am
It is done in the Dash, not the PDM.
Re: KEYPAD
Postby godrift on Wed Apr 16, 2025 10:34 am
Stephen Dean wrote:It is done in the Dash, not the PDM.
but in the keypad buttons what should be added inorder to press and let the order works. as you know in the keypad button there is options under led1 and led2 to select options. this what im confused dont know what to use inside.
godrift
Re: KEYPAD
Postby Stephen Dean on Wed Apr 16, 2025 11:02 am
Here are a couple of options on how to do it. Your dealer should also be assisting you with this as this is part of the contract that they have with us when they become a dealer.
Buttons from PDM.c127v65
(1.34 MiB) Downloaded 47 times
Buttons direct from KP.c127v65
(1.34 MiB) Downloaded 45 times
E46 2JZ PDM30-1 Configuration (DASH).pdm
(99.61 KiB) Downloaded 46 times
Re: KEYPAD
Postby godrift on Wed Apr 16, 2025 12:05 pm
Stephen Dean wrote:Here are a couple of options on how to do it. Your dealer should also be assisting you with this as this is part of the contract that they have with us when they become a dealer.
first really thanks for the support, but i belive i made mistake when i said page up and down.
i meant the boost up and boost down to control from keypad not the display page.
sorry again. my mistake.
godrift
Re: KEYPAD
Postby Stephen Dean on Thu Apr 17, 2025 3:56 pm
Same process, just us the Boost buttons instead.
Re: KEYPAD
Postby godrift on Sun Apr 20, 2025 7:37 am
Stephen Dean wrote:Same process, just us the Boost buttons instead.
thank you
godrift
