I NEED small help about combining pins
can i combine two pins 8A for example pin b1 & b2 total if i combine them will be 16A
is it possible to do this
David Ferguson wrote:You can combine two (or more) outputs, but it's important that they use the exact same condition to become active. I usually create a function that is true when the ganged outputs are to be on, and use this function as the condition for each output.
Also, set the same cuirrent limits for each output - say 1/2 the expected total for two outputs.
