by greenamex2 on Mon Jun 03, 2024 6:29 am
Any reason you can't just the values in the standard ECU "PDM" transmitted data and some functions?
To transmit CAN messages to a MoTeC PDM set PDM CAN Bus to the CAN bus connected to the PDM. All selected output resources of the following kind: 'PDM Byte x Mask xx' are transmitted on ID 0x11A. In addition, the following messages are transmitted on ID 0x118:
•Byte 0 (Data size 8 bit, Mask FF, Divisor 1): Engine Speed in rpm/100. This will result in a value of e.g. 21 for an engine speed of 2100rpm.
•Byte 1 (Data size 8 bit, Mask FF, Divisor 1): Throttle Position in %.
•Byte 2 (Data size 8 bit, Mask FF, Divisor 1): Vehicle Speed in km/h.
•Byte 3 (Data size 8 bit, Mask FF, Divisor 1): Coolant Temperature in °C.
•Byte 4 (Data size 8 bit, Mask FF, Divisor 1): Engine Oil Temperature in °C.
•Byte 5 (Data size 8 bit, Mask FF, Divisor 1): Fuel Temperature in °C.
•Byte 6 (Data size 8 bit, Mask FF, Divisor 1): Transmission Temperature in °C.
•Byte 7 (Data size 8 bit, Mask FF, Divisor 1): Differential Temperature in °C.
Motec CDL3+M130+LTCD+MDD+PDM15+PDM16M
