+12V input?
+12V input?
Postby greenamex2 on Sun Dec 20, 2020 7:47 pm
Hi all
Anyway of triggering a PDM input of a +12V signal without resorting to a pull down resistor?
Thanks in advance
greenamex2
Re: +12V input?
Postby RR213 on Mon Dec 21, 2020 6:40 am
When configuring the input pins there is the option for active high or active low. For 12v switched inputs use active high.
PDM Input Test.PNG (35.57 KiB) Viewed 12407 times
RR213
Re: +12V input?
Postby greenamex2 on Mon Dec 21, 2020 6:58 am
RR213 wrote:When configuring the input pins there is the option for active high or active low. For 12v switched inputs use active high.
Unfortunately when no 12v signal is present the source isn't pull to ground so the pdm still gets pulled to +12v anyway by the internal pdm pull-up!
greenamex2
Re: +12V input?
Postby adrian on Mon Dec 21, 2020 8:20 am
The PDM switch inputs were originally designed for pull to ground type switching so unfortunately the only way to wire a 12V switch into the PDM is by adding a pull down resistor.
Re: +12V input?
Postby greenamex2 on Mon Dec 21, 2020 8:27 am
adrian wrote:The PDM switch inputs were originally designed for pull to ground type switching so unfortunately the only way to wire a 12V switch into the PDM is by adding a pull down resistor.
Thanks for confirming Adrian.
I have managed to work how to fit them inside a Rostra cruise control stalk.
greenamex2
Re: +12V input?
Postby Ae92 on Sun Jul 03, 2022 6:21 am
How would you wire a pull down resistor in please ?
Ae92
Re: +12V input?
Postby Stephen Dean on Mon Jul 04, 2022 10:14 am
You need to wire a 1500ohm 0.25w resistor between the Input wire and the 0V wire. The Trigger levels for the input should be set to 4V and 5V for correct triggering.
Re: +12V input?
Postby Ae92 on Sat Jul 23, 2022 6:57 am
SDean wrote:Hi,
Thanks mate
I was going to wire 12+ ignition switch to my pdm30 if I was to add a pull down resistor would I still be able the use accessories still wired to the ignition switch ? (I have my alarm system still wired to my ignition switch)
Ae92
