PDM30 Firmware update trouble
Postby plosey on Fri Oct 19, 2012 2:34 am
Hi, I have two of your PDM30's and i have moved to a new laptop. I need to update the firmware on one of the pdms from 1.4 to the new 1.5 (I can do this fine via the pdm software) however when i go to connect i get
Communications Error:
Read Operation Failed: PDM Halted reason code WRONG_CFG_VER
Attached is a screenshot of the error.
plosey
Re: PDM30 Firmware update trouble
Postby GWRMOTORSPORT on Sat Oct 20, 2012 2:17 am
Hi Plosey
I had a similiar issue when I tried to upgrade from 1.4 to 1.5 about a year ago,
If I recall the fix was to update the old 1.4 config file on the laptop into 1.5
and then update the pdm to 1.5 then resend the config file
Hope this helps
Steve
GWR Motorsport
UK
GWRMOTORSPORT
Postby plosey on Sat Oct 20, 2012 2:45 am
Thanks, Yes that is the email i got from Motec as well and it did work. was a simple fix just needed a point in the right direction, TY
plosey
Users browsing this forum: Majestic-12 [Bot] and 7 guests
