High resistance conditioning
Postby Holmz on Mon Jan 26, 2009 1:22 pm
I have some sensors that vary their conductance (1.0/resistance) linearly with pressure.
The resistance range is ~30k-Ohms to ~1M-Ohm.
How do I get this into an ACL?
Do the standalone thermocouple amps (I think #58008??) have the same/identical amplification as the circuits in an E888?
And what are the technical specs for the thermocouple circuits in gain, offsets, etc? Is there a math equation for the response with respect to resistance? Or is it a gain with respect to current (I think that they are current devices).
Either way I would like to understand the circuit behaviour.
For my particular resistance/conductance logging, will I need to precondition the signals with an OP-amps?
Re: High resistance conditioning
Postby JamieA on Fri Jan 30, 2009 9:05 am
The thermocouple amplifiers are high input impedance, high gain voltage amplifies. Thermocouples can not supply much current and have a very low resistance across the terminals. I don’t think this sort of amplifier would be suitable with your sensor.
If you are using a VIM with your ACL I would try using an analogue input with a weak pull up (perhaps 100K) to 5v. The inputs on the VIM have very high resolution so you don’t need to use the full range of the input (0-5v) to have useful data. One side of the sensor needs to go to 0v and the other to the input on the VIM with the pull up.
David
JamieA
Return to ACL and VIM
