VIM Testing
We are running an ACL and 3 VIMs. We had some data that with a lot of drop outs, the sensors were swapped and the problem persisted on a specific input. I ran through my usual checks and nothing obvious seems to be wrong with the remainder of the setup (hard and soft).
To bottom out this and future problems I would like to bench test the VIM, could some one give me the back ground under which the VIM transmits/responds onto the CAN bus.
Will I need to recreate the ACL explorer messages etc... it does not simple passively transmit onto the bus.
I'm after a repeatable bench test for checking out my VIMs before deciding there is a probelm and returning them to base, which always takes lots of time. I also like to do as much of the problem diagnostics at the workshop so that we can track down the root problem and defining a test for the VIMs is a good step towards that.
Cheers, J.
Cheers, J.
