AIM Strada on CAN
AIM Strada on CAN
Postby TurboMiles on Tue Jan 05, 2010 11:40 am
If I connect the AIM to can and M600 to can everything works and displays properly. If I connect the UTC and M600 I can read write to the M600. If I connect AIM, M600 and UTC everything work, but the when I hook up the usb cable to my laptop I can't get comms with M600 and the AIM won't display.
My can bus is a shielded twisted pair in a jacket with a 100ohm resistor on one end, the UTC is 5' away 10"from the other end of the can bus.
With everything connected I get 35ohm on the bus. Any help would help :mrgreen:
TurboMiles
Re: AIM Strada on CAN
Postby IDP on Tue Jan 05, 2010 5:18 pm
I would start with another resistor on the other end of the bus.
That should help.
It is not an unusual problem with AIM dashes combined with MX00 however.
IDP
Postby TurboMiles on Mon Feb 01, 2010 3:59 am
Not sure I solved the problem, but I got it working by changing the data rate from 1mbit to 500kbit in Motec software. Now it works everytime. It is a little slow when retrieving a log from Motec, but it works.
TurboMiles
Return to ADL3, SDL3 and CDL3
